Fuel tank rusted-where can i buy a new one from?
monstr2
Post by monstr2 »
My car is a JDM,REV 1,3SGTE and i have recently discovered that the fuel tank has become rusted from inside and i'd like to know where i can get a new one from as it is not available in Lithia toyota. Thanks.
Draven
Re: Fuel tank rusted-where can i buy a new one from?
Post by Draven »
Wow well i'm pretty sure you could get one from Toyota UK. But I should imagine the postage costs horrendous.
No idea really mate. :cry:
monstr2
Post by monstr2 »
Tracy at Lithia toyota says its not being made anymore.
Draven
Post by Draven »
monstr2 wrote:Tracy at Lithia toyota says its not being made anymore.
Ah yes. Sadly it is around that time. Last time I tried to get parts I was told that they were no longer being produced. :? You might be able to get old stock. But i'm afriad you might be looking more towards getting one from a breaker. I did have a breaker a little while ago but scapped it with the tank in simply because it was too much of a pain to remove.
thomp1983
Post by thomp1983 »
if it's not too badly rusted then you could probably use something like petseal or por15 or similar if it's available in india
Rob
Post by Rob »
I've not heard of this in the UK, Europe or US, not from the inside anyway.
Without wishing to offend, is it a likely result of poorer grade fuels in India?
If so, it will happen again and I wonder if you could put any sort of coating inside to protect it from happening again?
monstr2
Post by monstr2 »
Rob wrote:I've not heard of this in the UK, Europe or US, not from the inside anyway.
I have heard that if you leave the car sitting for a long time with a small amount of fuel in the tank then it will catch rust.
My car came with a rusted tank and fuel pump when i bought it.
This has not happened with any other car that i have owned not even my 14 year old DD.
monstr2
Post by monstr2 »
thomp1983 wrote:if it's not too badly rusted then you could probably use something like petseal or por15 or similar if it's available in india
I dont know how effective this will be and i've been told the rust always reappears after some time as has happened with my car.
Draven
Post by Draven »
Rust will always appear eventually this is the bain of all mild steel. Por15 will seal it for a while. You're probably best looking for a breaker in India.
monstr2
Post by monstr2 »
Draven wrote:Rust will always appear eventually this is the bain of all mild steel. Por15 will seal it for a while. You're probably best looking for a breaker in India.
There are probably a total of 100 MR2's in my cuntry so i will have to buy the tank from either the U.K. or the U.S.
raptor95GTS
Post by raptor95GTS »
unfortunate typo lol but aye that's going to be an expensive postage :(
C35Rob
Post by C35Rob »
you could also try hong kong - closer to you and has a big "JDM" scene, or japan, or australia / NZ. sourcing a tank will be easy, finding someone willing to ship one may be harder. it may even be cheaper to have a rectangular tank fabricated in your own country. as it wouldn't take a fabricator too long (probably a day?) and I imagine labour costs aren't too bad.
how about some pics of your car too?
monstr2
Post by monstr2 »
Do you think it will be possible to fabricate a tank as it is very odd shaped and there are also the valves and fittings that go into it?
Cant post pics here but heres a link :) http://postimg.org/my.php?gallery=31idula10
Draven
Post by Draven »
It is possible to fabricate anything given the time and expense.
