Like most places these days, Nobles use TAT software which uses coast down loses to estimate drivetrain losses, its not perfect but its better than a
% guess.
Anyone with a GCSE in physics ought to figure out that straight
% loss calculations are a waste of time.
From what I can gather the coast down losses offer an empiracle alternative which seems to be pretty acurate.
Conversely working with wheel figures only, seems to provide a huge variation in power figures for the same car, on the same day as things like the tyres, and transmission warm up for example.
Even though the engine is still making the same, or usually less power on each succesive run.
Interestingly enough the TAT software will allow you to plot pretty much anything you like, so if you asked they could plot rwhp instead, however most decent dyno centers that have bothered to invest in TAT software will present you with a fwbhp figure from the losses.
Its your money, its your choice.
Having spent more time on dyno's than most, I usually like to see both.
Neiol.
