Anyone have any ideas.
The blue hose is hanging down at first I thought it went there.
Just a bit confused.
glen n wrote:I think if fitting a boost controller none of that is needed.I've been stripping my car and don't
seem to have any of the tvsv parts under the inlet manifold.
jimGTS wrote:You don't need one to get the car started or boosting.
It will simply just run actuator pressure.![]()
(Block right had port on actuator, and run line from left hand actuator port to turbo).
You use the mbc/ebc to up the boost, this fits between the actuator and turbo.
