3SGE Beams VVTi engine.
It's has gradual coolant loss from the overflow which suggests a pending head gasket failure.
leak down and a sniffer test.
Compression was approx.
Leak down was approx.
No hydrocarbons were detected in the coolant.
The car does not overheat and has never overheated but this is because I maintain the coolant level.
Thers is no coolant in the oil or white residue under the oil filler cap.
It drives as normal with no perceivable loss in power.
Regardless of the above, coolant is still being forced from the overflow.
The first 250ml is lost quickly under load then it will settle to gradual loss.
General condition and spec:
Mileage is currently at approx.
Corrosion has started at the rear of the sills and on the drivers door
The car has had panel repairs/replacements at some point
Aftermarket Parts:
Phoenix's Power Header
Phoenix's Power exhaust with down pipe.
Unbranded de-cat pipe.
Stainless intake pipe.
HKS MAF housing with air flow straightener.
Unbranded K&N style cone filter
NGK Iridium plugs.
Brash Boy Apex Power FC with hand commander
TRD front
BC Racing RM Series
FR 5kgmm RR 8kgmm.
Wilhelm Raceworks geometry correction kit.
Tein Tension Rods
Megan Racing tie rod ends with bump steer correction.
Super pro poly bushes
Whiteline 20mm rear arb with poly bushes
Cusco front and rear strutbraces.
OEM droplinks all round.
EBC redstuff pads
CRN slotted and semi-drilled discs
HEL stainless lines.
Volk Racing GT-U FR 16x7 ET35 RR 16x8 ET35
10mm hucentric spacer at rear to clear calipers.
Uniroyal Rainsport 2 FR 205/45 RR 225/45
Raybrig headlamps with Phillips bulbs.
It's had a recent refurb alternator and offside front caliper from Camskill.
Cam belt was done at 100000km
I didn't keep much in the way of paperwork but you'll find all the parts are their and were fitted circa 2011/2012.
Test drives will be performed by me unless proof of fully comp insurance is provided.
The car is currenlty taxed until September 2014 and MOT'd until March 2015.
Price:
Hopefully someone can make good use of the parts on their fast road or track build.
If you are interested, please contact by PM and details can be exchanged.
Car is Located in Falkirk.
![Image](http://i.imgur.com/MyPKMuP.jpg)
![Image](http://i.imgur.com/7l4kD83.jpg)
![Image](http://i.imgur.com/loLtvTf.jpg)
![Image](http://i.imgur.com/pLktQGC.jpg)
![Image](http://i.imgur.com/TXZNFtm.jpg)
![Image](http://i.imgur.com/6qX7d4N.jpg)
![Image](http://i.imgur.com/x9U75iN.jpg)
![Image](http://i.imgur.com/M2nAJn1.jpg)
![Image](http://i.imgur.com/sdaod15.jpg)
![Image](http://i.imgur.com/9vAl9xi.jpg)
![Image](http://i.imgur.com/7J6dMz8.jpg)
![Image](http://i.imgur.com/qg4Ywd1.jpg)
