[Mk2] [Turbo] Rebuild - 500 HP CANDY RED MR2
Re: [Mk2] [Turbo] Rebuild - 500 HP CANDY RED MR2
only for the Handbrake
3 x 8 mm screw
here you can see the complete brake
rear:
front:
3 x 8 mm screw
rear:
front:
sw22 wrote:only for the Handbrake!
3 x 8 mm screw
ok, I just had not seen for handbrake
Frontscheibe eingebaut:
RyanRs wrote:What have you got planned for the handbrake cable?
RyanRs wrote:RyanRs wrote:What have you got planned for the handbrake cable?
15mm H&R Spurplatten verbaut
Blitz Blow-Off, Ladedruckventil eingebaut
und Turbolader am Wasserladeluftkühler angeschlossen
Adapter für Temperatursensor des Wasserladeluftkühlers angepasst.
In diesem Adapter wurde noch eine Verbindung vom oberen Teil des Wasserladeluftkühlers zum Wasserkreislauf gezogen, um die Luft aus dem Wasserladeluftkühler zu bekommen.
Venturi Effekt
sw22 wrote:Blende nochmals um zwei Anzeigen erweitert:
what size
thats just stunning
Work of art, awesome build, can't wait to see a video of it on the road, well done
sw22 wrote:
oo they look nice
Did you make those headlights yourself? I don't think I've ever seen those before.
They look very very good!
