[Mk2] [Turbo] idle and stalling
sketchmyster
Post by sketchmyster »
got a mk2 rev2 turbo and had a problem checked for codes and came up with code 52 which ive changed the knock sensor however the car now stalls after hard acceleration. no codes sowing
Baker
Re: [Mk2] [Turbo] idle and stalling
Post by Baker »
Are you hitting fuel cut?
What PSI is it hitting?
sketchmyster
nope not hitting fuel cut as only running standard boost at mo but has been running and raced at 1.2 bar with no problems
Nic
Post by Nic »
sketchmyster wrote:the car now stalls after hard acceleration. no codes sowing
So it's stalling when you are coming to a stop after accelarating? Do you have a vent to atmosphere blow off valve fitted?
Nic
[email protected]
MR2 Rev 3 GT Turbo
sketchmyster
yer a friend has said release it abit so have but havnt tried it yer
dobbar
Post by dobbar »
Mine did the exact same thing, was thinking BOV was on it's way out whereas in fact it was simply down to a dirty ISCV !
Peter Gidden
Post by Peter Gidden »
Sounds like usual Rev1/2 problem.
Either ISCV is not operating correctly, or a cheap rubbish ebay dump valve or branded better dump valve is leaking.
If ISCV is OK, refit the OEM dump valve.
sketchmyster
thank you for the info
