G'Box oil
Re: G'Box oil
MR2 Rich wrote:Mine took 3 bottles of MT90 so just under 3 litres.
Are you sure?
Manual says that it need 4.2ltr.
Here is some good info: http://mr2.noegruts.com/mt-90/mt-90.htm
Re: G'Box oil
That page links to the page Nic posted.
MT-90 comes in quart bottles, I believe.
http://mr2wiki.com/Main/E153Transmission
Re: G'Box oil
A bit OT, but MR2 Rich, did you feel any difference in gear change after filling with MT-90?
I have a big problem with crunchy gears on track.
For daily use it's ok, but at high rpms it's terrible.
Re: G'Box oil
is 75w90 redline gearbox oil ok?
Re: G'Box oil
The Rev3 Turbo onwards take less oil due to the LSD taking up space within the gearbox.
My gearbox was a little hard to get into gear but I think that was mainly due to the bushes on the gear linkages.
It felt like a new gearbox after I changed them.
I would definitely recommend changing them as well.
I did the oil at the same time as the bushes so can't really say if the MT90 did much, it was more for piece of mind knowing my car has got the best oil in.
Hope that helps.
Hope that helps.
No 2
