At Long Last.... Pistols 1.5 swap
SySanguinary
Re: At Long Last.... Pistols 1.5 swap
Post by SySanguinary »
pistol pete wrote:Thanks mate
My cable doesn't seem long enough, the cable reaches but the wire is a tad to short
Is that washers either side I the black bracket to hold the cable?
The washers were a make shift way of adjusting the slack in the cable. They were cut through to enable them to be used as shims.
pistol pete wrote:
Also I am missing the thing the 2nd recirc pipe connects to, what is it??
Ta
Sorry, not sure which bit you are refering to.... :-k
pistol pete
Post by pistol pete »
There are 2 small vac pipes coming off the recirc
One goes to the intake manifold not sure where the other goes
pistol pete
got a few job to make up at work tonight but today i did this..
also fitted the intake today
next couple days will see
holes in floor for the IC, and a scoop later
clean up the boot
mount up and connect ECU on ally plate
Mount the oil filter relocator
make bracket so the throttle cable sits correctly
fit overflow coolant bottle
fit and connect battery
turbo/fuel tank fire wall make and fit
Get the exhaust this weekend
then start and tune
4ndee
Post by 4ndee »
i dont wanna worry you but.......theres a big hole in your boot! i wouldnt keep your shopping in there
pistol pete
4ndee wrote:i dont wanna worry you but.......theres a big hole in your boot! i wouldnt keep your shopping in there
ahh bu88er, i was gonna use it for the family shopping trip and holidays.. wheres the luggage gonna go now!!
4ndee
Post by 4ndee »
roof rack and tow bar?
pistol pete
well had a busy night.. me and guy from work (mainly hime)O been making 1.5 parts..
first off the new boot plate..
nice IC scoop
And lastly always hated the standard water bottle so he made me a new one.. much nicer..
still works as it should with the main pipe in to water and the overflow pipe..
will be mounting this in the boot
also made a plate for the ecu to sit on as well as mount of the oil filter relocator :)
Magic Beans
Post by Magic Beans »
You've been a busy boy Pete. Love the metalwork :thumleft:
Ben
Post by Ben »
:aghast: Shiny.....
Good work. I love the simplicity of the coolant level indicator :thumleft:
Previous:
Peter Gidden
Post by Peter Gidden »
pistol pete wrote:There are 2 small vac pipes coming off the recirc
Take a look here:
http://imageshack.us/photo/my-images/89/mr2bpvwq0.jpg/
Sounds like you may have a few bits missing.
pistol pete
Yep I am missing that vtv ;)....
Anyone got one?
Pretty pleasse
pistol pete
wanted to have done more but the weather has not really been in my favour
but today was clear so managed to finish the boot today, quite pleased,
yes I know the battery should be under bonnet etc, but I would like at least one usable space are in the car so using the boot for everything then can use under bonnet, if I do find it causes an issue I will move it later on
I started to do the gear linkages today, but really struggling with them, that's gonna take some head scratching(and phone calls), and a spring clip I have lost
drive shafts also now have boots on and just need putting on the car, alternator belt and heat shield, exhaust on and she's ready to go...
ashley
Post by ashley »
Wow - some serious progress Pete, nice one...this is gonna be a hoot on the track!
:mrgreen:
Magic Beans
I know I've said it before, but you've done an awesome job on this Pete :clap:
pistol pete
grrrrrrrrrrrrrrrrrrrrrrr I have pput my clutch line down this eve somewhere so I can take it to work to get male=male connector and can I bleeding find it grrrr
if I find that dog has nicked it grrrrrrr
pistol pete
Magic Beans wrote:I know I've said it before, but you've done an awesome job on this Pete :clap:
thanks mate.. I am sure its not as perfect as this pics suggest.. but its my first time doing it and im enjoying it :)
SySanguinary
Looking good Pete. As for the battery in the boot... that's what I did. It meant I had enough space in the front to carry all the tools I needed. Just in case!
pistol pete
SySanguinary wrote:Looking good Pete. As for the battery in the boot... that's what I did. It meant I had enough space in the front to carry all the tools I needed. Just in case!
yeah my thats my thoughts to.. and for JAE bits otherwise there would be next to no storage space...
how did you get the gearlinkages to work>>>???
SySanguinary
PM sent. I'll see if I can find any pictures too.
pistol pete
woohoo
it turned over.. ]but have a fuel leak which I want to hunt and sort before connecting the coil and actually trying to start it but got a stinking cold and headache, don't want to break anything in frustration so I am off back to bed//
