Red REV1 Hack @ Failure Update
synXero
Re: Red REV1 Hack @ Failure Update
Post by synXero »
It's been done a lot, check out the forum TwoBrutal for all the info on engine swaps (V6s, V8/10/12s also!). You'll have annoying problems being the early rev1 like a mechanical speedo instead of electric though.
lowslowandold
Post by lowslowandold »
Will have a look but properly keep it standard, not planning on spending to much on her (famous last words)
KarlBristol
Post by KarlBristol »
lowslowandold wrote:Will have a look but properly keep it standard, not planning on spending to much on her (famous last words)
I remember typing almost the exact same statement... Your view will change :lol:
Magic Beans
Post by Magic Beans »
I remember saying there's no way I'd ever want more power than it had when I bought it.. :eye:
Magic Beans wrote:I remember saying there's no way I'd ever want more power than it had when I bought it.. :eye:
I remember thinking: "ah a nice stock rev3 turbo, that's how it will stay........"
............... :twisted:
:lol:
lowslowandold
Today I managed to get a key cut using the drivers door barrel, and so I can at least take the steering lock off, put on the jump pack and it doesn't turn over, or hear a fuel pump priming, but have feeling the old Clifford alarm is causing that problem so tomorrow will start hacking out the alarm and hopefully start her and see what happens :)
Will also try and get on the ramp see what 9months of English weather has done :pale:
lowslowandold
its alive....
after 20 odd minutes cut out the old clifford alarm and ended up with this
and then this happened
a little rattly until oil got everywhere, but none starts and runs sweet, will get her on the ramp and see whats what, there is slight knocking from the front some where and need to sort out the sill where some idiot jacked it up wrong, may even treat her to a service and k&n panel filter
need to give it a good clean and sort her out a radio, but so far £115.50 spent
lowslowandold
so the girl failed her MOT, anti roll bar links all round, ball joints all round, and front shocks no dampening effect, and rust on the sills at the back
so sorted this lot out:
the shocks and springs in the post thats to MrTwo, and hopefully spend some time fitting all this next week
but what cleaning/valet products do people use, esp looking at turning the pink to red :mrgreen:
pistol pete
Post by pistol pete »
I always use Meguair's..
Ultimate compound would do what you want followed by a polish, don't forget to claybay it first though..
Or i use meguiars 205 (check amazon) :thumleft:
Not too bad for an mo for what you paid for the car.. keeping an eye, good luck :thumleft:
Ryan S
Post by Ryan S »
lowslowandold wrote:esp looking at turning the pink to red :mrgreen:
red paint!!! the problem is the paint is so thin, or maybe mine was just buffed too many times prior to me buying it, when i buffed it, i was through to the under coat in many places :(
lowslowandold
Bought some products today, will see what happens mostly meguiars stuff (in offer at the parts company) and will see what happens :-k
lowslowandold
hopefully this will get the old shiela firing up again,and can continue fiting the suspension parts
lowslowandold
now running again, then cut out and smoked from the engine, thinking the worst the coil pack had burnt out it was rotten and full of rust
suspension all fitted, still a knock from the front must be the anti roll bar d bushes, will sort a set out asap.
then time bust out the welder and repair the sills at the back
