I know there's quite a lot of people on here who are interested to see how things hold up, including myself.
Keep us updated.
I suppose I can use this to update how long the engine lasts& how well the car does on the drag strip.
rs007 wrote:
To those talking about US popular boost limits in pump fuel- isn't their fuel really crap octane?
Like 93 ish?
Like 93 ish?
Sorry to bump the thread, but just to pick up on this, 93 US is same as our 98/99, so directly comparable.![]()
They just measure octane directly to us.But is comparable.
Ps, GTR going well, but isn't without it's innitial issues! Now 450-500+ hp safely, and feels fab.
rs007 wrote:Idiots question because you have already stressed the stockness of the stock engine
But need to be one million percent sure
Stock compression ratio?
Bob Hatton was saying in a thread I started on fueling that this is the defining limiter on 3s-gte power, implication being it will det itself to pieces if the boost is pushed, and to be fair the stock CR is higher than most similarly specced engines.![]()
But through aggressive inlet charge cooling, and good fueling, you've avoided this, yes?
I'm guessing so, since it didn't turn into a jap 4 cylinder grenade, Jeff Hartman also exceeded the commonly quoted power ceiling both inexpensively and easily.
Reliability for the rest of us using them as road car is naturally going to be a concern, but I acknowledge that is not what this project is about.![]()
But then, I doubt many road users are as hard on their cars as multiple runs up the strip lol!
Like 93 ish?
gazrev1tubby wrote:I think you need to map mine next!
Al-sw20 wrote:Great result.![]()
chaos19810 wrote:Loved reading this someone who is willing to just go for it and see what happens and share the details.![]()
Keep it up and can't wait to see what happens
bobhatton wrote:You have to run a lot of boost to get that power, with 2.2 bar boost and some high octane fuel you should be up around 650hp.
I expect you have retarded the ignition timing back too far, try and richen up the fuelling and put the timing back where Toyota designed it to be and it should be much better.
silverspeed wrote:Metal head gasket.![]()
Not quite stock.
Not quite stock.
silverspeed wrote:Very impressed mate.![]()
Looks a little laggy though..
I managed 500 in me 185 with the tvis still fitted, it became an issue then.
