[Mk2] [Turbo] first run after HG fix etc, idles fine but go t pull away but stalls
really frustrating me now, but now got the car idling fine, ignition idling and timing belts is spot on, but when you go to pull aways just runs rough and stalls
- IMOC Moderator
Re: [Mk2] [Turbo] first run after HG fix etc, idles fine but go t pull away but stalls
sounds like either a mammoth boost leak or AFM not plugged in
(rev1/2)
sheppy wrote:sounds like either a mammoth boost leak or AFM not plugged in(rev1/2)
thanks for a reply
its a rev 1 the afm is plugged in.
- IMOC Moderator
hmmmm, could be a number of things but i'd start with checking for boost leaks, i had the same problem on a rev2 while driving, turned a corner then car cut out, started no problem and idled, went to drive off and it cut out, the plug for the AFM had popped out,
sheppy wrote:hmmmm, could be a number of things but i'd start with checking for boost leaks, i had the same problem on a rev2 while driving, turned a corner then car cut out, started no problem and idled, went to drive off and it cut out, the plug for the AFM had popped out,![]()
- IMOC Moderator
fuel pressure, have you checked it?? might be enough for the car to idle, but not enough to drive.
sheppy wrote:fuel pressure, have you checked it?? might be enough for the car to idle, but not enough to drive.
i havent no, bit silly but how do i check?
- IMOC Moderator
with a fuel pressure gauge,, it'll plum into the fuel line, you'll need to find out what tha actual pressure should be, then obviously see what pressure you have, if it's low, you'll need to replace the pump
sheppy wrote:with a fuel pressure gauge,, it'll plum into the fuel line, you'll need to find out what tha actual pressure should be, then obviously see what pressure you have, if it's low, you'll need to replace the pump![]()
but it was working fine before i took it all apart for HG so should still work?
- IMOC Moderator
haha, yeah i guess it should, but is it?? that's the problem with problems
sheppy wrote:haha, yeah i guess it should, but is it?? that's the problem with problems
haha yeah but so frustrating.
what else major do i need to look at
any other ideas?
04kendalld wrote:sheppy wrote:haha, yeah i guess it should, but is it?? that's the problem with problems
what else major do i need to look at?
any other ideas?
i have now sorted my first issue now the car runs
and the second problem is.
when driving
any ideas on a solution to my issues would be great as i need to drive it too work monday
thanks for all help given.
with the turbo issue, you can hear the car spool but no increase in power, just a loud not nice sounding boost at low revs?
- IMOC Moderator
are the actuator lines connected properly?? what did the first problem turn out to be?? do you have a boost gauge
(not the standard one) connected?
sheppy wrote:are the actuator lines connected properly?? what did the first problem turn out to be?? do you have a boost gauge(not the standard one) connected?
bit silly but it was only running
i have an omoni boost gauge, idling it reads
- IMOC Moderator
all a bit odd mate, sounds like something not been put back together properly, vac lines etc.
it's easy to do with a big job like the cylinder head.
is the car showing boost when you drive it??
- IMOC Moderator
still sounds like you have a boost pipe off,
sheppy wrote:all a bit odd mate, sounds like something not been put back together properly, vac lines etc..
defo no boost pipes off lol, will check tomorow if he car is reading boost, i think it is could it be the
which is why im puting standard boost back on.
am jacking the car up and fitting hose clips to the ones that need it.
04kendalld wrote:sheppy wrote:all a bit odd mate, sounds like something not been put back together properly, vac lines etc..
defo no boost pipes off lol, will check tomorow if he car is reading boost, i think it is could it be the£13 boost controller from ebay?
