[Mk2] [Turbo] first run after HG fix etc, idles fine but go t pull away but stalls
04kendalld
Post by 04kendalld »
really frustrating me now, but now got the car idling fine, ignition idling and timing belts is spot on, but when you go to pull aways just runs rough and stalls ?
Ryan S
Re: [Mk2] [Turbo] first run after HG fix etc, idles fine but go t pull away but stalls
Post by Ryan S »
what rev?
Ryan S
Post by Ryan S »
sounds like either a mammoth boost leak or AFM not plugged in (rev1/2)
04kendalld
sheppy wrote:sounds like either a mammoth boost leak or AFM not plugged in (rev1/2)
thanks for a reply
its a rev 1 the afm is plugged in.
Ryan S
Post by Ryan S »
hmmmm, could be a number of things but i'd start with checking for boost leaks, i had the same problem on a rev2 while driving, turned a corner then car cut out, started no problem and idled, went to drive off and it cut out, the plug for the AFM had popped out, :(
04kendalld
sheppy wrote:hmmmm, could be a number of things but i'd start with checking for boost leaks, i had the same problem on a rev2 while driving, turned a corner then car cut out, started no problem and idled, went to drive off and it cut out, the plug for the AFM had popped out, :(
Ryan S
Post by Ryan S »
fuel pressure, have you checked it?? might be enough for the car to idle, but not enough to drive.
04kendalld
sheppy wrote:fuel pressure, have you checked it?? might be enough for the car to idle, but not enough to drive.
i havent no, bit silly but how do i check?
Ryan S
Post by Ryan S »
with a fuel pressure gauge,, it'll plum into the fuel line, you'll need to find out what tha actual pressure should be, then obviously see what pressure you have, if it's low, you'll need to replace the pump :thumleft:
04kendalld
sheppy wrote:with a fuel pressure gauge,, it'll plum into the fuel line, you'll need to find out what tha actual pressure should be, then obviously see what pressure you have, if it's low, you'll need to replace the pump :thumleft:
but it was working fine before i took it all apart for HG so should still work?
Ryan S
Post by Ryan S »
haha, yeah i guess it should, but is it?? that's the problem with problems :D
04kendalld
sheppy wrote:haha, yeah i guess it should, but is it?? that's the problem with problems :D
haha yeah but so frustrating.
what else major do i need to look at ?
any other ideas?
04kendalld
any other ideas?
i have now sorted my first issue now the car runs ,but the car boosts as soon as i put my foot on the accelerator, any ideas why?
and the second problem is..
when driving ( car is warmed up) the car feels like its juddering, it feels like the afm is unplugged and just stops starts while driving.
any ideas on a solution to my issues would be great as i need to drive it too work monday
thanks for all help given.
04kendalld
with the turbo issue, you can hear the car spool but no increase in power, just a loud not nice sounding boost at low revs?
Ryan S
Post by Ryan S »
are the actuator lines connected properly?? what did the first problem turn out to be?? do you have a boost gauge (not the standard one) connected?
04kendalld
sheppy wrote:are the actuator lines connected properly?? what did the first problem turn out to be?? do you have a boost gauge (not the standard one) connected?
bit silly but it was only running on 3 cylinders, but thanks for all your suggestions.
i have an omoni boost gauge, idling it reads -50 iirc not sure but i think it shows it boosts but no increase in power, will check tomorow, i have a cheap boost gauge which tomorow will be removed and standard lines reconected.
Ryan S
Post by Ryan S »
all a bit odd mate, sounds like something not been put back together properly, vac lines etc... it's easy to do with a big job like the cylinder head. is the car showing boost when you drive it??
Ryan S
Post by Ryan S »
still sounds like you have a boost pipe off, :-k
04kendalld
sheppy wrote:all a bit odd mate, sounds like something not been put back together properly, vac lines etc... it's easy to do with a big job like the cylinder head. is the car showing boost when you drive it??
defo no boost pipes off lol, will check tomorow if he car is reading boost, i think it is could it be the £13 boost controller from ebay?
which is why im puting standard boost back on.
am jacking the car up and fitting hose clips to the ones that need it.
Tsia
Post by Tsia »
...I...what? :neutral:
