Exhaust Gaskets
SuperRedMR2
Exhaust Gaskets
Post by SuperRedMR2 »
Went to fit my exhaust gaskets this morning and they don't fit over the bores of my janspeed downpipe - anyone had this issue before?
smokeejoe
Re: Exhaust Gaskets
Post by smokeejoe »
Mine are a tight fit but i just bash them on with the palm of my hand, never had any problems with them not sealing.
How much to small are they?
SuperRedMR2
Re: Exhaust Gaskets
Mine just wouldn't go on.
Left them off (again) but i've got more problems that than.
elbon50
Re: Exhaust Gaskets
Post by elbon50 »
Have you ever been able to get gaskets onto the Janspeed pipes Alex ?
SuperRedMR2
Re: Exhaust Gaskets
To be honest no I haven't lol
The O/D of the pipes are about 1mm too big
un1eash
Re: Exhaust Gaskets
Post by un1eash »
Mine were a very tight fit too, dont use any exhaust putty either as it just breaks up after time and leaks,
SuperRedMR2
Re: Exhaust Gaskets
What is the I/D of an exhaust gasket? I'll see if I can source a slightly larger one.
The metal kept on almost falling apart when I was trying to force mine on. Wouldn't even go on with a hammer.
elbon50
Re: Exhaust Gaskets
Post by elbon50 »
SuperRedMR2 wrote:What is the I/D of an exhaust gasket? I'll see if I can source a slightly larger one.
I have a spare new one here Alex
ID is 43 mill minimum (varies a bit as I rotate the ring in the caliper)
Thickness is 5 mill
SuperRedMR2
Re: Exhaust Gaskets
Cheers peter i'll try and get an oversize gasket
elbon50
Re: Exhaust Gaskets
Post by elbon50 »
SuperRedMR2 wrote:Cheers peter i'll try and get an oversize gasket
Were the gasket rings you tried from Mr T Alex :?:
Spurious one may be slightly different size perhaps :?:
SuperRedMR2
Re: Exhaust Gaskets
The gaskets I had came from a head gasket kit so they were not from Toyota.
I might be able to get a Motorbike gasket
elbon50
Re: Exhaust Gaskets
Post by elbon50 »
SuperRedMR2 wrote:The gaskets I had came from a head gasket kit so they were not from Toyota.
Yeah, its just a thought. I don't know
The one I have here is a Mr T one
You've gone to work in the car then :?:
SuperRedMR2
Re: Exhaust Gaskets
The engine is in but i've got issues with it at the moment.
Waiting for advice from PW first, no offence Peter.
LimeyMk1
Re: Exhaust Gaskets
Post by LimeyMk1 »
If you measure the ID & OD you should be able to get one from an autofactors.
My local Camberley Autofactors used to have buckets of them (literally).
elbon50
Re: Exhaust Gaskets
Post by elbon50 »
SuperRedMR2 wrote:The engine is in but i've got issues with it at the moment.
No offence taken Alex
I'm just trying to help
You had the engine from Paul & naturally you'll ask him for advice :thumleft:
