Exhaust Gaskets
Exhaust Gaskets
Went to fit my exhaust gaskets this morning and they don't fit over the bores of my janspeed downpipe
- anyone had this issue before?
Re: Exhaust Gaskets
Mine are a tight fit but i just bash them on with the palm of my hand, never had any problems with them not sealing.
How much to small are they?
Re: Exhaust Gaskets
Mine just wouldn't go on.
Left them off
(again) but i've got more problems that than.
Left them off
Re: Exhaust Gaskets
Have you ever been able to get gaskets onto the Janspeed pipes Alex
Re: Exhaust Gaskets
To be honest no I haven't lol
The O/D of the pipes are about 1mm too big
Re: Exhaust Gaskets
Mine were a very tight fit too, dont use any exhaust putty either as it just breaks up after time and leaks,
Re: Exhaust Gaskets
What is the I/D of an exhaust gasket? I'll see if I can source a slightly larger one.
The metal kept on almost falling apart when I was trying to force mine on.
Wouldn't even go on with a hammer.
Re: Exhaust Gaskets
SuperRedMR2 wrote:What is the I/D of an exhaust gasket? I'll see if I can source a slightly larger one.![]()
The metal kept on almost falling apart when I was trying to force mine on.Wouldn't even go on with a hammer.
I have a spare new one here Alex
ID is 43 mill minimum
Thickness is 5 mill
Re: Exhaust Gaskets
Cheers peter i'll try and get an oversize gasket
Re: Exhaust Gaskets
SuperRedMR2 wrote:Cheers peter i'll try and get an oversize gasket
Were the gasket rings you tried from Mr T Alex
Spurious one may be slightly different size perhaps
Re: Exhaust Gaskets
The gaskets I had came from a head gasket kit so they were not from Toyota.
I might be able to get a Motorbike gasket
Re: Exhaust Gaskets
SuperRedMR2 wrote:The gaskets I had came from a head gasket kit so they were not from Toyota.
Yeah, its just a thought.
The one I have here is a Mr T one
You've gone to work in the car then
Re: Exhaust Gaskets
The engine is in but i've got issues with it at the moment.
Waiting for advice from PW first, no offence Peter.
Re: Exhaust Gaskets
If you measure the ID
& OD you should be able to get one from an autofactors.
My local Camberley Autofactors used to have buckets of them
(literally).
Re: Exhaust Gaskets
SuperRedMR2 wrote:The engine is in but i've got issues with it at the moment.
No offence taken Alex
I'm just trying to help
You had the engine from Paul
