It's a rev2 turbo 60k miles
Banksie
garry goodall wrote:my clutch release bearing makes a noise but only when the clutch isn't pressed..
don't know what to suggest about that one.
Slarty wrote:garry goodall wrote:my clutch release bearing makes a noise but only when the clutch isn't pressed..
Surely it should only make a noise when the clutch is depressed as that's when the release bearing is in contact with the fingers on the pressure plate![]()
Twin plate clutches rattle but I doubt that that's the OP's issue
