Anyway, the 2nd pic:
MR2Mania wrote:alex205mi16 wrote:ah, i was confused, i thought these were say 8" x 4" plastic bits attached infront of the wheel, didnt realise they were a whole moulding inc the wheel arch..
steps down and shoots informant>
They don't include the wheel arch, mate.There's just a rib in the wheelarch, and these deflectors follow that contour so that they seal against the arch.
They
*are* basic things, but to try and knock something up from scratch that would look reasonably ok would be a false economy IMHO.
You've got to wonder whether the time spent is actually worth less than just buying them.Normally, that's how I personally compare prices on things that I could make myself.
I look at the price, look at how many hours it would cost me to make one, and if the cost to buy the thing ready is considerably cheaper than my time to make it I just go ahead and buy it!
ryan wrote:For starters does the outer screw go into the arch liner or the back end or the front splitter?
ryan wrote:
Dino, i've got those bits(2 of) coming in on saturday from Mr T
, so i'll let you know what they are!
peterguk wrote:Fitting is easy.
No idea why MrT only lists two bolts.![]()
I used three of them
(bolts with washer built in), and 3 flanged nuts.
Took 10 mins per side.
MR2Mania wrote:peterguk wrote:Fitting is easy.
Peter, can you confirm the part no for those"flanged nuts"?
Is it either of these part nos?
90387-10166
90387-07032
peterguk wrote:They came from me
I didn't like what the EPC supplied, so i looked through my stock and chose suitable M6 washer head bolts and M6 flanged nuts.![]()
Perfect job
