[Mk2] [Turbo] Speed sensor and boost gauge??????
les
Post by les »
Have error code 42 no speed signal, need to know where the speed sensor is and how to test. its rev3 so no speedo cable. also the boost gauge reads positive boost all the time even on tickover. car has been stood for 2 years and ran for the last 5 months but these have not settled down, any ideas.
cvega666
Re: [Mk2] [Turbo] Speed sensor and boost gauge??????
Post by cvega666 »
speedo sensor is on the gearbox, if you look down the engine on the dizzy side, it's hiding there. It could be wiring or possibly the plastic cog chewed by the gearbox - nothing too serious but you will need a new one... positive boost reading possibly a split hose somewhere..
les
Post by les »
Cheers will check that out
rev3turbo
Post by rev3turbo »
got a speedo sensor if needed
Shmed
Post by Shmed »
i might need that mate :)
January 2014
May 2015
Still in the garage...
Return to “Electrical”
