It has 106,400 miles
Its an Import T-Bar with a later rev3 3sge engine that was installed when I bought the car in 2005 and has had the following work done since I owned the car:
Clifford Concept 650 CAT 1 immobiliser and alarm with remote central locking fitted 2005
New T-Bar seals 2007
Rear disks and pads 2008
Front disks 2008 and pads 1 month ago also new calliper slider pins and seals
Inner and outer steering arms replaced Feb 2009
Front Drop links replaced 2010
Pi lowering springs 2006
K&N 57i Induction kit 2006 cleaned and re-oiled Feb 2010
Same colour re-spray with all the back parts colour coded 2006
Rocker cover gaskets replaced June 2011
Rocker cover, Inlet Manifold and Throttle body painted June 2011
Alternator belt replaced July 2011
HT leads replaced Feb 2010
Replaced drivers door 2010 due to rust
White El-Glow dials March 2010
Both handbrake cables replaced Feb 2006
New battery
Interior is half leather, It has a JVC DAB radio and JBL Speakers.
The paint has only ever been cleaned with microfiber cloths and has been regularly polished.
Now the bad parts:
Rust on both sills.
Rust on the rear drivers side wheel arch.
Drivers door slightly different shade due to a bad paint match when changed.
MOT advisory for all brake pipes.
Air Con does not work.
Seats arent in a good condition
Alloys need a refurb.
Not much tread on rear tyres, fronts have loads.
Needs wheel alignment done and possibly a front wheel bearing.
No service history
I am selling it due to not having the time to correct the above faults, as its my daily car I cannot afford it to be of the road while I carry out the work.
More here, including the bad bits http://s3.photobucket.com/albums/y79/Pa ... or%20Sale/
Tel: 07957585981
