That is not an easy thing to do with the gearbox on a bench so going to be very hard with it in the car.
I had to put a lot of heat into the bolt then shock it with lots of cold water to get it out.
Then had to use a puller to get it off the shaft.
I think the new rubber boot
£13.35
