djpkins wrote:If the DP is a new one then I would skim a wee bit off
the inside where it's snagged.
.but if it's not, then the wastegate just blew open too much cos the actuator rod wasn't attached.
.but you should try slackening the easier to get to ones first just incase it gives you enough play.
.fks sake though man.
.don't bend the DP flange.
.it will blow forever.
Ok sorted it, decided to go out tonight and give it a bash.
Managed to get away with just taking off the top bolts in the downpipe.
Freed up the wastegate and got the actuator arm back on.
But I could NOT get the circlip back on for love nor money.
Then managed to drop and lose it!! Grrrr!
Oh and succesfully managed to snap the cable for the o2 sensor whilst I was at it.
God knows easy one of those are to pick up.
Wonder if Toyota stock them?
