hi
i'm not sure whether its usable to be honest,
the turbo itself is brand new and confirmed as a KKK,
but i have no idea what the compressor map would be and in that respect
it may not spool untill way up the rev range,
then again i could be wrong.
It was cheap enough so if i cant use it im sure i wont lose out,
anyway heres a couple of pics see what you think
cold side compressor inlet is 75mm
cold side outlet is 60mm
hot side T4 footprint to manifold
hot side to downpipe is 4 stud kkk 75mm inner 100mm outer
exhaust shell is 180mm
cold side shell is 180mm
The guys at work say it will be fine on a diesel bus lol
cheers
steve
