Screw in studs till they bottom out, do up hand tight.
Fit each nut and your supposed to screw them on then take them back off and back on again FOUR soddin times!
-its to mate the threads together.
-make sure moly lube is on there or 30wt oil.
Torque to 60 ft/lb
1000miles later, bottom out studs then re-torque to 60ft/lb
Shamed
- these are designed NOT to stretch! its the main point of them over stretch bolts.
The reason for the re-torque is because on first torque they will not lock into there seated position due to there lack of streching and low torque value,they will therefore slowly loosen off.
Stretch bolts get torqued down a lot tighter so they dont loosen off.
