[Mk2] [Turbo] Swap 3sgte gen3 on mr2 rev1 3sge na
arnaud_mr2
Post by arnaud_mr2 »
hi,
i have a problem with my swap.
my engine not start. the starter is ok, fuel pump ok, ignition ok.
The engine not start because the injector not open. i have 12v on the injector and the resistor pack is ok. I have test my ecu on an other mr2 and the ecu is good.
Please help me (sorry for my english i'm french).
arnaud_mr2
Re: [Mk2] [Turbo] Swap 3sgte gen3 on mr2 rev1 3sge na
injectors not pulsing fuel.
always is good but the probléme is ecu #1 #2 #3 #4.
I think that is a earth probléme on the ecu but i'm not find the probléme.
The earth harness is correctly connect on the manifold.
djpkins
Post by djpkins »
I don't understand what fault codes your reporting...could it be your distributer...have you got a good spark on all 4 cylinders...is your ecu earthed out correctly...if not it could get damaged...hope the weather is better in France than over here...rain
djpkins
Post by djpkins »
...you would get a better response posting this in the "mechanical" section matey :thumleft:
Return to “Electrical”
