How do do open the frunk in the short term?
How easy is it to fit a replacement cable?
JeffD wrote:Are you sure you havent accidenatlly disabled the trunk release by turning the key in the opposite way to normal to lock it?Theres a feature that if you lock it by turning the key a certain way the inside release wont work
(its the
"valet" locking mechanism).
I'd check thi8s first before replacing anything.
