I would like to know what this car is worth, please.
Reason(s) for refusal to issue Certificate
Rear fog lamp tell tale not working
Offside Rear fog lamp not in good working order
Offside Front Headlamp insecure
Offside Front Headlamp aim too low and too far to the left.
Nearside sill Seat belt anchorage prescribed area is excessively corroded
Offside sill Seat belt anchorage prescribed area is excessively corroded
Nearside Registration plate lamp not working
Nearside Rear sill Suspension component mounting prescribed area is excessively
corroded
Offside Rear sill Suspension component mounting prescribed area is excessively
corroded
Nearside Rear Suspension arm locating pin retaining device missing
Nearside Steering rack gaiter split
Offside Steering rack gaiter split
Offside Rear Tyre tread depth below requirements of 1.6mm
Rear Rear brake application uneven
Nearside Rear parking brake recording little or no effort
Parking brake efficiency below requirements
Front brakes imbalanced
Advisory Notice issued
Nearside Rear Shock absorber has a light misting of oil
Off side rear brake cal fixing bolts incorrect
