Gents,
I thought I'd wire in my SW20 AP Engineering PFC to my 1990 ST185 this weekend.
I repinned my harness extension, plugged my JDM gen2 ECU(89661-17380) for which my PFC was made for and turned the key.
IGN to SPARK to IDLE
So I proceeded to plug in the PFC and it fired up without any CELs and all sensors were working via the PC Commander screen.
I start going through the idle learning process with the PFC and I am able to get a steady 850-900revs at idle.
When I turn the A/C on, the engines hunts for idle continuously and you can hear the A/C clutch engage/disengage every second.
When I check the sensor screen on my commander the AC and ACR sensors are flashing.
I plugged in the JDM ecu and the A/C works fine.
So I know the wiring is ok.
Anyone with a PFC have any ideas
