Here is a spec list.
Should give an idea of the extent of the project.
Engine
86.5mm CP Pistons 9.0:1 CR
Ceramic Coating Applied To Combustion Chambers
Ceramic Coating Applied To Valve Faces
Ceramic Coating Applied To Piston Crowns
Lubricating Coating Applied to Piston Skirts
Lubricating Coating Applied To Inlet Ports
Lubricating Coating Applied To Exhaust Ports
Lubricating Coating Applied To Valve Stems
Heat Dissipation Coating Applied To Underside of Pistons
Head Skimmed by 0.005
Chambers CCd at 51cc
Block Decked by 0.003
0.021" Over Bored Block
Straight Check on Crankshaft
Crack Detection on Crankshaft
Crankshaft Journals Lapped
Eagle H-Beam Conrods
ARP Conrod Bolts
ARP Main Studs
ARP Head Studs
TOGA HP Main Bearings
TOGA HP Rod Bearings
TOGA HV Oil Pump
New Thrust Washers
CatCam Custom 3SGE Intake Cam
CatCam Custom 3SGE Exhaust Cam
Head Modified To Accept Cams
CatCam Adjustable Cam Pulleys
CatCam 3SGE Gen.
3 Valve Springs
CatCam 3SGE Gen.
3 Valve Spring Retainers
Power Enterprise Gen.
3 Super Strong Timing Belt
Unorthodox Racing Crankshaft Pulley
Machined to accept Trigger Wheel
Balanced Rotating Assembly
New Idlers
New Water Pump
New Gaskets and Seals
New Coolant Pipes
(rear of engine)
New Timing Belt Tensioner
Moroso Racing Oil Sump
75mm Polished Mustang Throttle Body
Phoenix Power Departure 2 Pro Exhaust
TRD Thermostat
1/2" NPT to
-12AN Aluminium Threaded Adapter for Oil Outlet
M18 to
-4AN Aluminium Threaded Block Adapter for Oil Feed
M28
12AN Aluminium Threaded Sump Adapter
4AN Oil Feed Line
12AN Oil Return Line
HKS SSQV Blow Off Valve
Red Silicone Water Hoses
Garrett GT35R
.82 A/R Turbo T3 Inlet w/ 3" v-Band Exit
Oil Feed Fitting w/ Restrictor
GT-Turbo Oil Return Flange and Gasket
Water
/ Coolant Line Fittings
Tial 38mm Wastegate Silver w/ 0.7bar spring
HKS SSQV Weld-On Mounting Flange
Mk3 Shimless Bucket Conversion
RU-5045 K&N Universal Air Filter
57-79mm Constant Tension Worm Drive Clamps
70-92mm Constant Tension Worm Drive Clamps
95-118mm Constant Tension Worm Drive Clamps
RMR Side Feed Half Round Inlet Manifold
Denso Grade 8 Spark Plugs
1.4mm Cometic Head Gasket
Earls
-3AN(JIC) Braided Oil Pressure Line
Mocal Oil Pressure T-piece
Engine Lid Fan Kit with 2x 10 Spal Fans
Engine Lid Fan Kit controlled by ECU
Custom 8 Injector Fuel System on Inlet Manifold
Quad Fuel Rails
Pectel SQ6 ECU
NTK Wideband Kit
8x 600cc Top Feed Injectors
Goodridge Braided Fuel Lines
Goodridge Fittings
& Adapters
Goodridge Braided Vacuum Lines
Custom Fuel Swirl Pot
Bosch External Fuel Pump
Custom Ram Horn Exhaust Manifold
Custom 3 V-Band Downpipe
Custom 1.5 Screamer Pipe
Custom Boot Mounted Intercooler 12 x 24 x 4
2x 11 Spal Fans Mounted on Intercooler
Intercooler Fans controlled by ECU
Air Injection Boost Control System
Roose Motorsport HTNS Silicone Couplers
Roose Motorsport Silicone Coolant Hoses
Magnetti Marelli 3 bar MAP Sensor
Magnetti Marelli 1 bar MAP Sensor for Barometric Correction
Custom Stainless Steel 3 Intake Pipes
Custom Engine Wiring Loom
Cam Cover Modified for Twin
-8AN Breathers
Custom Breather Tank
Custom Distributor Blank Off Plate
Individual Coil Packs
3SGE Throttle Cable
Maxspeed Motorsports
-10AN Oil Filter Relocation Kit
Custom Aluminium Vent Block Off Plate
Transmission
New Gearbox Fill
& Drain Plugs
New 5th Gear
New 5th Gear Hub
All New Seals
All New Bearings
All New Synchros
Celica ST165 3.933 Ratio Final Drive Output Shaft
Celica ST165 3.933 Ratio Final Drive Ring Gear
Celica ST165 3.933 Ratio Final Drive Oil Pump Gear
Kaaz 2-way LSD
New End Plates
Aluminium Gear Shift Drop Plate Bushings
Gear Shift Linkage Bearings
ATS Chrome-Moly Inner CV Joints
New CV Boots
OS Giken Twin Plate Pressed Aluminium Cover Clutch
(R2CD)
OS Giken Flywheel
ARP Flywheel bolts
Earls Single Piece Braided Clutch Line
Earls Fittings Throughout
New Master Cylinder
New Slave Cylinder
Interior
MOMO Hub
Sparco 383 Rally Steering Wheel
(track wheel)
Sparco Aluminium Gear knob
Sparco Aluminium Pedals
Custom A-Pillar Single Gauge Pod
2x Dash Mounted Gauge Pods
Dash Mounted Flight Switch to Override ECU Fan Control
Engine Kill Switch
Electric Kill Switch
Digital EGT Gauge
Sparco Speed Bucket Seats
+ Stock Rev2 Cloth Seats
Custom Seat Runners
SHIFT-i Sequential Shift Light
Steering Cowling Modified To Mount SHIFT-i
Prosport Stepper Smoked Boost Gauge
Prosport Stepper Smoked Oil Temp Gauge
Prosport Stepper Smoked Oil Pressure Gauge
Digital Volt Meter Custom Mounted In Clock Housing
2008 Civic Start Button
Interior Dash Panels painted satin black
High Tensile Harness Eye Bolts
Willans 3 Clip in Drivers Harness
Willans 2 Clip in Passenger Harness
Exterior
Bomex Aero 2 Mirrors
Raybrig Head Lights
Diamond Clear Bumper Lights
Front
& Rear Running Lights
Alloy Mesh in Side Vents
Rev3 Light Conversion
Quad Tail/Brake Light Modification
Flat Wiper Blades
-- Border Vent Extensions
not yet fitted
Wheels
& Tyres
Team Dynamics DRIFTZ
(front 7x17
+et35 rear 9x17
+et35)
Toyo Proxes T-1R 215/40 17 front
Toyo Proxes T-1R 245/35 17 rear
-- Falken 452 215/40 17 front
Brand new
not yet fitted
-- Falken 452 245/35 17 rear
Brand new
not yet fitted
Brakes
& Steering
Custom 324mm Big Disc Conversion
Mintex Front Brake Pads
Mintex Rear Brake Pads
Goodridge Braided Brake Lines
Brake Master Cylinder Brace
Earls Solo Bleed Nipples
-- Custom Steering Universal Joint Spacer
Not yet fitted
Audio
Pioneer DEH-6900IB iPod controller Headunit
+ aux input
Pioneer TS-E176C 6.5 components
Infinity 6x9s mounted on Custom plates in Cubby Holes
Chassis
TEIN Flex Coilovers
TEIN Pillowball Top Mounts
High
& Tight Prothane Bushes
Custom Drop Links Front
& Rear
Motoria Strut Braces Front and Rear
V-Max Anti Torque Bar w/ Custom Rear Bracket
