mk1 lost keys
mk1 lost keys
any suggestions how to get into my mk1 mr2 mislaid the keys
Re: mk1 lost keys
If you have lost the keys then getting in is the least of your problems.It takes all of 20 seconds to get into a locked mk1 but i'm not about to share it on an internet forum.
Re: mk1 lost keys
am sure you will figure out how to get in the mk1, but if you open up the inside of the door, behind the panel and take out your driver side lock, it will have the numbers on it and you can get the keys cut.
I went to toyota for it for my friend but they said a locksmith will do it for cheaper and you get spares etc
Re: mk1 lost keys
mmmmm.
first post and you want to get into a MK1 without the keys
I may be totally wrong here but don't think I want to help!
Re: mk1 lost keys
Shadeh wrote:am sure you will figure out how to get in the mk1, but if you open up the inside of the door, behind the panel and take out your driver side lock, it will have the numbers on it and you can get the keys cut.![]()
Whereabouts on the lock should these numbers be out of interest? I've got locks from various cars in the garage and whilst having a quick look over them the other week the only obvious number I noticed was a 4 digit one on the lever arm.
Re: mk1 lost keys
if I remember correctly its along the side of the lock and should be unique to each mk1, so was good enough for them to cut a key and it worked first time
Re: mk1 lost keys
PW@Woodsport wrote:If you have lost the keys then getting in is the least of your problems.It takes all of 20 seconds to get into a locked mk1 but i'm not about to share it on an internet forum.
Re: mk1 lost keys
Re: mk1 lost keys
Does the car have an alarm or immobiliser on it? I've had to bypass the one on my car after it had been sat without power for 2+ years.
Re: mk1 lost keys
Limeymk1 wrote:Does the car have an alarm or immobiliser on it? I've had to bypass the one on my car after it had been sat without power for 2+
years.
you go about bypass immobiliser
Re: mk1 lost keys
I simply pulled the alarm relay and bridged the connections in the relay plugs with some heavy duty wire.
Finding the alarm/immob's the fun bit.
It's a temporary thing as I'll be replacing the alarm but it had to be done so I could test the electrics.
Re: mk1 lost keys
Limeymk1 wrote:I simply pulled the alarm relay and bridged the connections in the relay plugs with some heavy duty wire.Finding the alarm/immob's the fun bit.
Re: mk1 lost keys
There was no factory alarm/immobiliser fitted to the mk1.
Anything you have got will be aftermarket or at best dealer fit so no-one here can tell you where it is or how to disable it.
Re: mk1 lost keys
kaiowas wrote:There was no factory alarm/immobiliser fitted to the mk1.Anything you have got will be aftermarket or at best dealer fit so no-one here
Re: mk1 lost keys
kaiowas wrote:There was no factory alarm/immobiliser fitted to the mk1.Anything you have got will be aftermarket or at best dealer fit so no-one here can tell you where it is or how to disable it.
