hub nut size
hub nut size
what is the size of the castellated nut that fits on the rear hub? im trying the find a socket that fits it.
- IMOC Moderator
Re: hub nut size
It's a 32mm mate:)
Re: hub nut size
you will also need a deeper than standard socket
Re: hub nut size
And do it with the wheel on and the car on the ground with blocks under the wheels
It may just be my crappy handbrake at the time but the torque needed to loosen the nut was greater than the handbrake could stop
Re: hub nut size
They're meant to be torqued to 218ft/lb, so I would think that is easily enough to overcome some handbrakes.
Re: hub nut size
the nut was actually a 30mm socket.
and its all torqued down and good to go now
- IMOC Moderator
Re: hub nut size
Sorry buddy, I just assumed you had a tubby:)
Re: hub nut size
sheppy wrote:Sorry buddy, I just assumed you had a tubby:)
It's easy done
- IMOC Moderator
Re: hub nut size
marty1 wrote:sheppy wrote:Sorry buddy, I just assumed you had a tubby:)
It's easy done
Ha ha! I do that all the time!
