ok, car back together.
i tried bridging the b+ and fp, made no difference.
still sounds like its missing on 1 cylinder.
(but not missing on the rev3 ecu).
the leads are firing on each cylinder
so in guessing its just not firing 1 of the injectors??
like i said above, ive checked all continuty from each injector plug to the resistor plug, and all have continuity to the resistor pack plug were there soldered
(as there high impedance injectors).
.finally found out how the resistor pack has been bypassed.
anyone confirm these are sard 850s???
(getting 4.3k ohms.
looked at the sensor check, no black boxes, and all the Volt readings were moving.
some more than others.
now regarding the TPS, ive checked and the st205
(rev3+ engine) online BGB, its different to the USDM rev1/2 in terms of resistance readings.
mine are actually in spec, apart from the 0.9mm feeler gauge test, it doesnt go to infinity, needs a little more opening for the resistance to go to infinity, but apart from that, all within spec.
now unfortunatly the st205 bgb, hasnt got the
"ignition" section, so i cant check the coil.
now as said above, was only getting 0.08ohms on the coil pack,
USDM rev1/2
says its ment to be 0.41-0.5ohms, but not sure if the gen3 engine is different
(well the tps was different)
click on throttle body, and youll see the resistance specs for gen3
http://www.celicatech.com/imagearchive/ ... /EG/EG.htm
my results against the bgb table
im getting 0.4k ohms
0.03k ohms
0.05k ohms
(not infinity)
2.85k ohms
3.8k ohms
now coil???
anyone any ideas where i can find the bgb specs for it????
any more ideas folks????
apart from swapping in a known working powerFC, im not sure what else to check.
this is the fruit of my labour anyway, getting off all my engine parts, cleaned and painted.
