Hi guys and thanks for the replies!
The main reason I want an aerosol is becasue I was going to be a bit lazy.
I was intending to port match the inlet and exhaust manifolds to the head as they have smaller ports then the ports on the head.
I Have the head stripped so I was going to use a plastic pipe extension
(the ones you get with wd40
/ carb cleaner) ram it down the port
(on the valve side) and blast it at the edges of the inlet
/exhaust manifold that protrude into the ports on the head.
(the head/manifolds would be bolted together at this point and the runners on the inlet manifold would be blocked up
I was thinking that the dye would effectivley give me a nice outline of where the inlet
/ exhaust manifold if smaller than the head ports and I could then subsequently grind the rest away so the manifolds match the head.
Then just clean it all up with thinners when done?
Does that sound daft?
RS is a good bet and I didnt think of that, however do they sell to the public?
Regards
James
