Yes, but the brackets are differenet so you will have to swap that too.
The turbo brackets are bigger than the N/A, they bolt to the same holes on the block its just the bracket itself the turbo alternator wont fit inside a N/A bracket .
If you car is a N/A and you want to put a Turbo alternator on it you will need the bracket definatly as the Turbo alternator wont physically fit in the bracket.
If you car is a Turbo and you want to put a N/A alternator on it then you may get away with just using a spacer on the Turbo bracket, as the N/A alternator will physically fit in the bracket but will be loose.
Hope that helps.
Lewis.
