My electric aerial has been broke for 3 years, not a problem for me as I usually just listen to CD's and so unplugged the aerial to stop the whining noise from the broken
'worm'.
I bet you're now thinking, why not just pull the mast up then? well because it looks like a RC car imo
Anyway now the warm weathers coming, the car will be used and the girlfriend will probably moan there is no radio, so ive been searching for aerial options, the common ones would be replace the mast or replace the aerial, but thats usually
£££ and I have better things to spend my cash on.
So searching the internet I found a cheap
£5 internal glass aerial:
http://www.uniqueaudioandstyling.co.uk/ ... -201-p.asp
cant go wrong for
£5 posted, but i thought it would look a bit ugly placed on the rear screen, so decided to mount it in the rear center panel
the aerial:
a nice place for the aerials body to sit
stuck to the body work, and then the panel will sit over! the wiring run to the right light cluser, through the grommet and hooked up to the existing aerial loom
works a treat! great reception, no nasty aerial hanging from your wing, 30mins to install and
£5 delivered!
