MOT Failed- Emissions
01smiffy
Post by 01smiffy »
Sorry guys
Car failed MOT on CO Emmissions! i have not done anything since last MOT which passed no problems!
I have a rev3 turbo with no Cat
The CO readings are 2nd fast ideal test 0.520 & should be no more than 0.300!
gargage reckons is the Lambda senser?
Any advise would be great!
Ian Geary
Re: MOT Failed- Emissions
Post by Ian Geary »
so you're sure you are being tested against the non cat emission level, rather than the with cat level?
it depends on your car's age though - around 1995 was the cut off year at which turbos had to be measured against the more strict with cat levels.
cheap tings to do to try and reduce emissions:
- get the mot done when the car is hot
- stick a new air filter in
- clean or replace the plugs
- run redex through the tank
- spray carb cleaner into the trottle body
These worked for me with my old VW...but they're intuituve enough.
you could try re-directing the crank breather to atmosphere, but this itself is an MOT fail.
expensive things to do
- replace the lamba sensor
- fuel injector cleaning etc
hth
Ian
jim55
Post by jim55 »
add an oil change and a new filter to the list .i had this last week for mot,i changed the oil ,new fresh petrol and air filter took it out for a right good blast (and really work the engine to get any deposits blown out)passed no prob :thumleft:
Matt_Cooper
Post by Matt_Cooper »
My Rev 3 N/A cleared the emissions even without a cat.
raptor95GTS
Post by raptor95GTS »
plenty of threads about this issue but without a reg letter advice is muted. M plate or older do Non CAT test, read the sticky at the top for further info
http://www.imoc.co.uk/forums/viewtopic.php?t=43072
