t-bar with a leak
mister_si23
t-bar with a leak
Post by mister_si23 »
has anyone else have the problem of leaking on drivers window and if so how did you resolve it.
raptor95GTS
Re: t-bar with a leak
Post by raptor95GTS »
http://www.allanwelsh.dsl.pipex.com/mot ... rLeak.html
fixed mine about 18 months ago using the sealant
jim
Post by jim »
Here's a link to the knowledge base
http://www.imoc.co.uk/forums/kb.php?mode=cat&cat=14
there are 3 articles worth checking out:
Fixing A Leaky T-Bar
Replacing Weatherstrips
T-Bar eccentric rod guide installation.
All of these offer a solution to this problem, with differing costs. I guess it depends on how badly deteriorated the weatherstrips are.
Jim
GIZMONKEY
Post by GIZMONKEY »
IF IT'S FOR THE T-BAR I HAD SAME PROBLEM.......I WIPED MY RUBBER STRIPS DOWN AND SMEARED ON VASELINE.............NO WET SEATS SINCE THEN
raptor95GTS
GIZMONKEY wrote:IF IT'S FOR THE T-BAR I HAD SAME PROBLEM.......I WIPED MY RUBBER STRIPS DOWN AND SMEARED ON VASELINE.............NO WET SEATS SINCE THEN
um vaseline eats the rubber :shock: - you might want to wash that stuff off and put something else on them instead
Martyn
Post by Martyn »
I just bought some new rubbers. (ooh that sounds bad)
Got them from Ebay off a Rev5 - virtually brand new for about £30. Fixed my leaks completely.
PW@Woodsport
Post by PW@Woodsport »
Yes! mine leaked like a beatch!
Remedy = i cut the roof off ! :lol: =D>
theredbottle
Post by theredbottle »
I've used Vaseline for many years on a Mk1 without any problem, just requires regular application i.e. perhaps twice a year.
Tony jinxy froude
Post by Tony jinxy froude »
PMSL :lol: :lol: You irish doughnut Woodsy !!!, Jinxy
crazylegs
Post by crazylegs »
i`ve used vasaline for many years too!! :^o
PW@Woodsport
yes but that was nothing to do with a leaking t-bar now was it kev??? :D
crazylegs
Post by crazylegs »
i knew someone would not be able to resist,now your on can you check the bearing post and see that i`m not talking brown stuff.cheers
