Another Group Buy has been requested, so setting this up to start getting names down for any and all those that are interested in the Big Brake Adapters.
I had to take a hit on the last lot due to some increases in part prices, other than that it's the same as before.
This is the
6th
Official Group Buy Thread for the
Big Disc Conversion kit
that I've designed.
Please ensure that you read, and acknowledge back to me that you have read and agree to the disclaimer, if you decide you would like to be included in the Group Buy.
This disclaimer will also apply when goods are received by you.
If you do not acknowledge your agreement you will not be included in the Group Buy.
Below is some information on the Big Disc Conversion kit:
- The Adapters will be CNC Machined from 6061 Billet Aluminium.
- The Adapters will then be Hard Anodised.
- Once the Adapters are complete, the kit will be sent out via Parcel Force to those who have purchased.
(Non UK address see notes below).
- The full kit will comprise of:
2 x Front Brackets.
2 x Rear Brackets.
2 x Rear Disc Centering Rings.
Required Mounting Hardware.
If you don't require the whole kit you must clearly indicate this.
Please state whether you require FRONT ONLY, REAR ONLY or FULL KIT.
I will leave this Group Buy open until the required number of names has been collected.
The minimum being 5 sets.
Once all names are in I will contact you for a Delivery Address, and to arrange payment of the kit.
All money will need to be received before the order is placed.
I will keep participants up to date as production progresses.
Prices for the kits are:
FULL KIT
£190
FRONT ONLY
£100
REAR ONLY
£110
There is a small increase in costs over the previous GB's, this is due to the unfortunate fact that the cost of parts and deliveries has gone up.
Please Note: GB Prices quoted are for
UK Delivery only
Non UK delivery will be quoted per enquiry.
For this I will need full address.
Deliveries will be Tracked
& Insured where possible although this may incur additional costs for non UK deliveries.
To complete the Big Brake Conversion you will need to source the following:
1 Pair of Toyota Supra Twin Turbo
"UK Spec" Front Discs
(324mm)
- use 1995 for part search
- Guide Price:
£149.50
1 Pair of Mazda RX8
"Sport" Front Discs
(324mm)
- use 2005 for part search
- Guide Price:
£112.65
Note: Some Motor Factors list them as 323mm discs and you will probably be able to find them cheaper if you know where to look.
Disclaimer:
Any problems with parts and fittings purchased and received will belong to the individuals participating in the Group Buy.
No liability is placed on me, Anthony Onions or the Manufacturing Company, CC Precision Engineering.
This modification has been designed for, and is in use on my own car.
The kit has not been, and will not be road tested prior to the purchase of the parts, fixtures and fitting so any liability of any kind will be the responsibility of the individual purchaser.
Any adjustments required will also be the responsibility of the purchaser.
Details of my MR2 can be found on
my website
, dated 29/10/10.
My observations for which I am not liable:
A very small clean up of casting marks on the Calliper mounting points may be required.
The Rear Calliper Mounting points require modifying to fit the Adapters.
The Dust Shields will need to be trimmed or manipulated to allow fitting of the Discs.
Please reply to this topic with:
"Username
- Required Kit
- Disclaimer Read
& Agreed"
Thanks,
Ant
Here is the kit that you would receive:
Useful links:
Fitting them to my own car
Original Big Disc Conversion discussion thread.
1st Group Buy thread.
2nd Group Buy thread.
3rd Group Buy thread.
4th Group Buy thread.
5th Group Buy thread.
