old engine coming out:
there it is, going into the garage to be stripped:
mean while i was working on my new block.
then along came the head, i mildly ported and polished the head, and bought some piper 264 cams and adjustable pulleys
cams now in and pullys on:
head on:
added the loom and all the other bits:
then an 11lb lightened fly for an mr2 Turbo and a 6paddle 2.2camry clutch went on
the cams were eventually dialled in, which i found hard to do as it was my first ever engine build, but i got there:
now for some gauges to monitor what the engine was doing:
oil pressure, oil temp and water temp, placed into my DIY holder:
time came after a bit more fiddling and after putting the gearbox on to put it back in the car:
and now for the exhaust to go on, it was for the turbo, so out cam the grinder and welder, with a few new flanges and a reducer pipe, and all was good:
so anyway, she started up on the third turn of the key, but wouldnt idle, which didnt matter as i had to run the cams in for 20mins at 2000rpm, after this i changed the throttle bodys and took her out for a spin.
its done about 1000miles now and just gone on to some fully synth shell oil.
would i ever do it again? hell yeah
