This thread is going around the world- from Lotus owners forums in Alaska to Skyline owner forums in New Zeland:
Well, I've been searching around quite a bit lately and found a ton of useful info, but I think I ran into a slight problem.
Ok.
My buddy said I should flush my engine after I got it in top running condition
(which is was in).
I drained out all my oil and kept the little screw guy out of the bottom of the big metal tank and then poured in a couple gallons of boiling water to clean everything out, which flowed the water out.
I put the screw back in, and I let it sit for a couple minutes, put in slick 50 and then started it for the 2 minutes that my buddy said to do and kept it at 5k rpms.
My motor then starting making this really loud knocking noise, which followed with a loud bang, and the engine shut off.
I'm afraid to try and restart it.
What do you think it could be?
That is just one post from a 9 page thread, it is the funniest thing I've ever seen.
Thread here:
http://forums.vwvortex.com/zerothread?id=1703095&page=1
