well i suggest you learn how things work then dude regarding boost controllers.
without running a fuel cut defendor, fcd, soon as you hit around 13psi, fuel will be cut to the engine, and itll hit a brick wall
(least thats how it feels).
you need to raise this fuel cut limit if you plan on running anything over 13psi.
(0.9bar), you use a fcd to do this.
error codes, please do this yourself, and dont pay anyone, all you need is a paper clip! and you can check it yourself! there is info on this on the knowledge base section.
igntion timing, if its to far advanced, youll be knocking and possibly detting, which is VERY bad for the engine, you need to check this is normal/correct with as timing gun.
