[Mk2] [Turbo] Getting Cambelt changed
01smiffy
Post by 01smiffy »
Watchya guys
Have got my car booked into garage to get the cambelt changed have been speaking to people and they recomended changing water pump, whilst doing the cambelt?
Is this correct because the garage never said anything about it?
Any comments would be greatfull!!!!
kev_mr2
Re: [Mk2] [Turbo] Getting Cambelt changed
Post by kev_mr2 »
yeah i would! isnt that hard to do and you wouldnt want it packing in a week after you get the cambelt done lol! do both idler bearings at the same time aswell!
Driftlimits Performance
IMOC Affiliated Company
might as well do oil pump too then!
Icsunonove
Post by Icsunonove »
Skywalker wrote:might as well do oil pump too then!
Christ! :mad: Is that prone to failure? Is it really worth changing that at the same time? How much is it? I really don't want to have to take it all to bits again :evil:
ian_106
Post by ian_106 »
How much is a water & oil pump then, this sounds like it could work out very expensive....
My point being guys is that it's very easy to get carried away and start replacing everything. In which case, yes, it gets expensive, but of course the car will potentially live longer.
The pumps on these very very rarely fail, and when they do, it's usually the relieve valve, or bits of bearing wearing them away.
I do many cambelts and only inspect the water and oil pump. But if you changing the water pump as a 'precautionary' measure, surely you'd be nuts not to change the oil pump. Infact, I'd replace the oil pump as a priority over the water pump.
It's your call :thumleft:
3S Service Centre
Post by 3S Service Centre »
3s pumps are good for a genuine 100k then you would expect to see signs of age, weepage from the seal in the oil pump/crank seal/and weapage from the inspection hole on the water pump. Changing the water pump and oil pump at the first belt changes pumps up the price and probably isnt required, but definatley on the second change.
James
HighwayStar
Post by HighwayStar »
Ooops! Just had my third change and not replaced any pumps! Oh well, lets just hope they last another 54k!
R.
HighwayStar
Just to add to the above post.... how much are new water and oil pumps?
R
01smiffy
Post by 01smiffy »
Cheers guys have spoken to the garage that is doing my cambelt said will take alook at it and let me know!
I roughly think water pump is going to cost about £70ish I think but don't quote me on it!!!
SySanguinary
Post by SySanguinary »
Just paid £51 from a local Motor Factors for mine. It's definately worth changing it as it will cost you more in labour to strip the car out at a later date than it will to change it now...
