[Mk2] [Turbo] cambelt snapped mr2 turbo rve 2
dizzi
Post by dizzi »
my cam belt (timing belt) snapped on my mr2 turbo rev 2 wot are the possibilties that my engine internal are bent or damaged includin head and piston and block etc pl help
3S Service Centre
Re: [Mk2] [Turbo] cambelt snapped mr2 turbo rve 2
Post by 3S Service Centre »
should be fine, get the cylinders leak tested then go from there.
James
dizzi
Post by dizzi »
but valve will be orite ! is a interfren oe non interfrence
luke1985
Post by luke1985 »
its meant to be a non interference engine, but only way to tell for sure if your engine is ok is to get it tested.. :(
Tiny
Post by Tiny »
well according to the books and the deisgn it would appear to be non interference get it checked out and let us know :thumleft:
