Right All.
First, apologies for the long post, but I have lots to go through, and thought it best to keep it all in one post.
Looking to get my first MR2
(N/A), and will be using it as a track day toy.
What mods are recommended first?
Have thought the following, but would be great to get some feedback, and some example prices if you have had similar mods.
Also, what have I missed?
1.
Strip it out
Loose as much weight as possible
- Any suggestions or recommendations here?
2.
Brakes
Brake pad upgrade
- what is recommended
Brake disc upgrade
- Does this make a great difference?
If so, what is recommended
(Don't think I would want to get a full brake/caliper upgrade, due to cost)
Braded hoses
- do these make much difference
What brake fluid should I use, and how often should I change it?
3.
Seats/Harness
Bucket Seats
& Harness vs.
standard seats and CG-Lock.
Anyone tried the CG-Lock?
What's it like?
Obviously buckets with harnesses will be much more expensive!
4.
Tyres
Thinking Toyo R888, as they seem to get pretty good reviews, but open to any other suggestions.
How long should I expect these to last?
5.
Petrol
Tesco 99 or Shell V-Power
- do these make any/much difference from running with normal supermarket unleaded?
6.
Roll-Cage
Don't think I'll be doing this.
Thoughts?
7.
Engine
Induction kit
- what is recommended?
Engine re-map
- is this at all worthwhile?
Exhaust
- not sure of this
- noise restrictions and all that, plus cost.
Does it provide any real improvement in performance?
8.
Suspension
Is the standard suspension ok to run on a track car, or is it far better to upgrade?
If so, what are good kits for the MR2.
Anything else?
Again, sorry for such a long post, but I would appreciate all feedback on any/all of the above!
Cheers, Mat
