been thinking of doing this for the last 2 years and now im well on the way.
i just purchased a rev3 rear clip so i have began stripping my car down to make way for the new power plant
pictures to follow.
firstly i removes both rear wishbones, then exhaust
then i went on to the boot.
i removed the ecu and all wiring to the rear lights and fed the loom through into the engine compartment
then into the passenger compartment.
i pulled the drivers seat out, glove box between the seats and the center console, then removed the gear cables and fed them through to the engine compartment.
next up was the wiring loom to the passenger footwell, i unpluged all the connectors and started pulling the tape off the wires, there are 2 thick wires that need to stay.
i worked my way back seperating these 2 wires from all the others and undone all the connectors all the way to the rear bulkhead.
i have sold the gearbox and exhaust, so they have now gone, so my engine is now resting on a 2"/4" plank of wood.
i will be buying an engine hoist and cradle in the next week or so.
then i will be able to remove the engine completely and give the engine bay a good clean.
then i need to buy a turbo fuel pump and get that plumbed in.
will update in a day or so.
