this is my first post so please be patient
hope someone could shed some light on this annoying problem, it's slowly driving me crazy
i've got a 92 uk Na t bar
The problem is this the pump from the power steering is interfering with the two subs.
things iv,e tried to solve this are:
](./images/smilies/eusa_wall.gif)
cheked for a good earth There is no resistance between a known good earth and the amp,
checked that all my wires run separatley from each other
even swapped the phono leads
I have the amp wired directly to the cars battery with a remote wire coming from the head unit.the earth is from a seat belt mounting
the amp is mounted near to the rear engine cover release.
is it just a case of the amp needs moving somewhere else.
maybe even just need to get rid of this amp and subs and put some 10inch ones in
thanks for your time and patiance any info or advise greatly recieved
Alec00
