[Mk2] [Turbo] Koni`s anyone???
Graeme Shaw
Post by Graeme Shaw »
Hi gang
Just fitted some standard struts with Koni inserts on the 2.
Any one got them on theirs?
If so how many settings is there? and which way do i turn them for hard or soft?
Cheers folks.
Graeme
Ian Geary
Re: [Mk2] [Turbo] Koni`s anyone???
Post by Ian Geary »
hi there
scientifically, there is an infinite number of settings, as the dial on top can be rotated about 720 degrees (ie twice round)
you should have got 2 white plastic knobs to adjust the strut, which shows which way is harder or softer. I keep one in the glovebox, another in the garage.
but I recall it is clockwise to firm the suspension, anticlockwise for softer (it screws something into the shock to reduce the flow of oil).
hth
Ian
Graeme Shaw
Anyone know where i can get a new koni adjustment tool from?
Have searhed ebay.
Graeme
MR-S Turbo
Post by MR-S Turbo »
Graeme Shaw wrote:Anyone know where i can get a new koni adjustment tool from?
Have searhed ebay.
Graeme
Ive got one you can borrow :thumleft:
Mr2GtBlue
Post by Mr2GtBlue »
I have one you can have :thumleft: I dont need any more as I binned my konis.
Graeme Shaw
That would be excellent!
Shall i pm you my address? Can i give you anything for it?
Graeme
mrfil13
Post by mrfil13 »
do you have the standard springs?
I have the koni inserts with standard springs, only just got them fitted the other week and adjusted them from the softest setting last weekend.
Feels nice and firm but not rock hard, kind of just tight feeling.
I found that they are 2.5 turns, the backs i turned to the softest and then did 1 turn to hardest, the front i turned to hardest then 1 turn back.
Graeme Shaw
Mine have eibach springs on. Think i need four whell alignment as it doesnt feel quite right. Then again maybe i just need to get used to them after having Teins on.
I have heard of having the back on the harder setting and the front on the softest?
Graeme
GHOST
Post by GHOST »
I had konis on my yeloow REV3 before it spun off the road. Apparently they'd altered all the geometry of the car which cause a bad wearing of the tyres. Just to advise you of that. Don't think mine was set up right by the garage.
Anyway, I found that the 'softest' setting was too hard and if I turned it up then it was boneshaking. A little too hard for me even on soft.
