Its not been touched since,not moved or engine turned over.
Any advice, as best way to start up without causing any engine damage?
I dont know yet wether it will turn over by hand.If it does,would an oil
Also the fuel, thats been sitting for the same length of time,is it likely to cause problems.
Yes, the brakes are seized and possibly the clutch.
All advice gratefully received
