Supercharger owners please read!
chiron
Post by chiron »
Hi,
If you are the owner of an AFM version of the 4AGZE (MR2 or AE92) please read on....
I have an enigne from an AE92 to fit to my MR2 but the AFM/MAF is missing. What I need is for some kind person to tell me the resistance measurements for the 4AGZE MAF fitted to either a supercharged MR2 or an AE92.
The resistance needs to be measured between the following pins with ignition off:
VS (pin 6 yellow-blue) and E22 (pin 2 brown)
VC (pin 4 yellow) and E22
VS and VC when flapper closed
VS and VC when flapper open
hopefully with this information I will be able to find out an alternative MAF that can be used and pass this information back to everybody during my build up.
thanks! =)
Mr2swift
Re: Supercharger owners please read!
Post by Mr2swift »
Please post the ecu numbers that came with your engine swap. It is important to know that some Ae92gze's are map based and therefor do not use an afm. You can use a 3sgte afm if you wish, but you must make sure what engine/ecu you have.
Ron
MartG
Post by MartG »
Values from the BGB
Hope that helps
chiron
Post by chiron »
My ECU is 89661-12171
its a rare beast, AE92 Trueno DLI with AFM. It also has an exhaust temperature sensor input THG/CCO that I think is for a JDM post-cat temperature sensor.
MartG
Post by MartG »
Rare indeed - I thought the AE92 GZE either had a dizzy and AFM ( early ones with bigport head, same spec as the AW11 ) or DLI and MAP sensor ( late ones, smallport head )
The engine will run fine without the cat sensor though
Edit : Checked, and no AE92 GZE had a dizzy :oops:
