Took the car out last night, i knew the right hand calliper had been sticking a bit but not this bad, i only went about 4 miles and could feel what i thought was the discs and pads rubbing.
Also got a bit of brake fade.
pulled into a lay by and i could smell the brakes as soon as i opened the door, the alloy was red hot to touch.
Do i need a new right hand calliper or can it be fixed with new seals? if so where is the best place to buy them from and what else will i need?
