[Mk2] [Turbo] D2 brake kits
DONUT69
Post by DONUT69 »
As above peeps just wondering has anybody had any experience with them. Tryed and tested
ebay search D2 brake kit mr2
Donut
karammander
Re: [Mk2] [Turbo] D2 brake kits
Post by karammander »
i've seen them before, they look good though.
i just got an email from ksport today sayin that have just realeased more brake kits for the mr2, i think its designed to fit inside a 16" rim.
worth a look if your after big brakes
cheers karam
DONUT69
Post by DONUT69 »
Cheers wil have a wee look at them
JAP BOY
Post by JAP BOY »
How much are the K-sport kits going for
DONUT69
Post by DONUT69 »
Was on the site earlier and depends on what size u op to go for.
for the 8 pot front u have the
330mm that starts at £727 and rises to £800 depending on the brake pads u go for.
356mm £850 - £935
380mm £1234 - £1293 serious brakes lol
The rears are 6 pot and the same price per disc size
JAP BOY
Post by JAP BOY »
Yeah thats not too bad but i think its only recommended that a 356mm disc fits behind a 17inch wheel also i take it the calipers wudn't need changing if you go for a bigger disc later on!!!
DONUT69
Post by DONUT69 »
Yea thats right about the 356mm
I would like to think that if u decided after a while to go for the bigger disk that it would fit ok.
Is a nice kit.
JAP BOY
Post by JAP BOY »
Ican see the 330mm kit working with the 356mm kit but i cudn't see the 330mm and 356mm kits working with the 380 mm kits
cantfindausername
Post by cantfindausername »
:-k hmm... Does anyone know if D2 or K-Sport actually test these kits? How well do they work with the MC fitted on our cars? They should have a recommended MC size for operating their calipers properly.
You might find you get more braking force from uprated components on your stock brakes. Obviously no where near as bling though!
***RIP Car13 ***
*** Now in an Evo ***
JAP BOY
Post by JAP BOY »
:-k That is a fairly good point mate no idea whether there is any info on how well they work with the MCs :)
cantfindausername
The only reason I ask is becuase I've done some looking intot brake kits, and from what I can gather, none are tested or show any reason to make you believe that they're worked out for the application they're listed for. Thats why when I get my brakes done I'll be going to a specialist and will have a set up that is designed for function, and the MR2. Not for bling.
Initial enquiries have led me to a price of £2.5k for a full custom designed front and rear set.
***RIP Car13 ***
JAP BOY
Post by JAP BOY »
At least that would have being tested mate but 2.k :shock:
I think more of our MR2 tuners should do abit more in depth developement into how to get the most from our cars!!!!!!!!!!!
Also us owners need to pitch ideas around !!!!!!!!!
Andy F
Post by Andy F »
In my Wilwood kit i got a bigger MC (Supra i think) and bias valve,Dont forget about hand brake, the D2s dont seem to show or mention anything about it.
raptor95GTS
Post by raptor95GTS »
JAP BOY wrote:At least that would have being tested mate but 2.k :shock:
interesting point but most folks will point out the range of pads available and also the impressive 60-0 one time stop distance. Therefore it's argued we don't need to upgrade the brakes for road use. The other pain in the butt is the rear handbrake / brake calliper. No other toyota uses this system so cheap upgrades aint an option. thanks toyota :thumleft:
JAP BOY
Post by JAP BOY »
Andy think the pic shown is just what they look like not the kit designed for the MR2!!!!!!!!!!!!
Ok so if you have a 400 whp mr2 wud you rely on pads/ discs to stop you quick enough or wud a upgraded rotor stop you quicker Alan i mean we have got Mr2s now running silly power 280Whp and above !!! :-k
raptor95GTS
dude I totally agree, I'm with you on upgrading the brakes. Look at a Boxster setup. Ish the same power / acceleration and top end and just look at the brakes on that. I'll never have that type of setup but it would be nice.
for info - the supra brakes are 325dia with 30mm width and the hat height is 3mm higher than the mr2. So in theory it won't knock the wheel offsets out by much. Add some GT4 callipers and that should be pretty hot.
JAP BOY
Post by JAP BOY »
Allan mate Gt4 calipers are a nightmare to fit apparently but what we would really need is some one offering the bracket to mount them to our hubs also to work out the handbrake :)
Andy F
Post by Andy F »
Hi-spec do a mounting bracket for stock rear brake caliper with a 335 disc, their front kit is really good too, Jonno had these on his car and were spot on!!!
JAP BOY
Post by JAP BOY »
Andy If you dont mind me asking how much were the rears with the mounting braket!!!!
Also how much were the fronts :)
Greddy-Matt
Post by Greddy-Matt »
Andy F wrote:Hi-spec do a mounting bracket for stock rear brake caliper with a 335 disc, their front kit is really good too, Jonno had these on his car and were spot on!!!
I can't find the rear set up on their website Andy, any pointers or do we need to call them to get a quote?
Matt
