I might be selling up - any ideas as to what price my 1994 Auto Rev5 look-alikey should fetch? Below describes it in its rev5 spec. BTW its a 1994 L and I'll be keeping the plate!
OWNERSHIP DETAILS
V5 Present: Yes
Are you the registered keeper (explain if No): No - registered to my wife
Number of previous owners including yourself: 2
How long have you owned vehicle: 3 Years
Reason for selling: Just bought a turbo
MOT Expires: 16/11/2008
Tax Expires: 31/05/2008
GENERAL CONDITION
Is there any evidence of bodywork repairs (explain if Yes): No
Give detail of any of paintwork condition ie. fading, rust, chips, dents: Excellent except for Slight rusting on underside of bottom lip on drivers door: Paintwork is excellent
SERVICING
Service history (explain): Yes - serviced by self, platinum plugs, genuine Toyota dizzy cap, rotor arm etc
Date, mileage and by whom last service was done:
Date,mileage and by whom last cambelt change was done at: 12/2004 82,630 miles
Do you have receipts for parts, work carried out, old MOTs etc (give details if Yes): Yes - all old MOTs and receipts for nearly every part bought - big folder about 1" thick
Give details of any repairs made to car: Toyota drop links and ARB bushes. Replacement power steering rack, ball joints, TRD heavy duty topmounts, replaed popup motors, recent Toyota handbrake cables.Both door frame seals, door selas and mirror selas replaced so no 'tweeter noise'.
Have you been advised by a garage of any repairs that should be made (explain if Yes): No
ENGINE
Any leaks (either oil or water) from engine (explain if Yes): Did have a slight oil leak from cam cover but now fixed.
Has any part of the engine been rebuilt ie. bottom end, new headgasket etc (explain if Yes): No
Any unusual noise from engine (explain if Yes): No
Any smoking from engine (explain if Yes): No
Does engine pull smoothly without misfires or flatspots through all rev ranges (explain if No): Yes
Does engine start easily when either hot or cold (explain if No): Yes
Detail any problems with engine not mentioned above you may be aware of: None.
TURBO (IF FITTED)
Turbo operates correctly (explain if No): n/a - not fitted
Standard or aftermarket turbo fitted (give details if aftermarket): Standard/Aftermarket
Detail any other modifications to turbo system such as coolers, boost controllers etc:
EXHAUST
Exhaust system including mountings in good condition (explain if No): Yes its a Blueflame SS exhaust fitted by Blueflame.
Is a catalytic converter fitted: No
If a catalytic converter is NOT fitted is one required to pass an MOT for this car: Yes and have kept old catalytic converter
RADIATOR AND COOLING
Are there any leaks from either radiator or cooling system pipes (explain if Yes): No
Are there any overheating problems (explain if Yes): No
TRANSMISSION
Gearbox operates correctly through all gears including reverse (explain if No): Yes
Any noise or vibration from transmission in any gear (explain if Yes): No
Any leaks from transmission (explain if Yes): No
CLUTCH
Can gear changes be made easily and smoothly (explain if No): Yes auto box
Any unusual noise such as whining from clutch (explain if Yes): No
ELECTRICAL
Do all the lights (sidelights, headlamps, indicators, hazard and reverse) operate correctly (explain if No): Yes
If fitted popup headlamps work properly: Yes - recently refurbed hinges and replaced motors
Horn sounds: Yes
Windscreen wiper works: Yes
Both power windows work: Yes
Heating and ventilation system work properly: Yes
Interior lights including dashboard all light: Yes
Speedometer and rev counter work: Yes
Do all other gauges such as temperature, turbo, voltmeter, fuel etc gauges work (explain if No): Yes
Are there any problems with battery or alternator that require the car to be charged with a battery charger: No
TYRES
Driver Front : Champiro 195/55/R15 6mm evenly worn
Passenger Front: Champiro 195/55/R15 6mm evenly worn
Driver Rear : Champiro 225/50/R15 6mm evenly worn
Passenger Rear : Champiro 225/50/R15 6mm evenly worn
BRAKING
Handbrake operates correctly and stops car rolling (explain if No): Yes, both cables recently replaced with genuine Toyota cables.
Brakes operate correctly and car stops in straight line when brakes are applied (explain if No): Yes
ABS working correctly if fitted: n/a
SUSPENSION AND STEERING
Does car drive in a straight line: Yes
Are spring and shock absorbers in good condition without leaks (explain if No): Yes but both front gators perished
Are there any knocks, noises etc from suspension or steering at LOW speeds (explain if Yes): No
Are there any knocks, noises etc from suspension or steering at HIGH speeds (explain if Yes): No
If power steering is fitted does it work correctly: Yes
Generally, does the car handle well (explain if No): Yes
BODYWORK
Both seatbelts work correctly including any warning lights (explain if No): Yes
Door locks including remote key fob if applicable work properly (explain if No): Yes
Type of seats: 1/2 leather/Alacanthra
Detail any damage to interior trim such as cigarette burns, scratches, worn seat bolsters etc: Driver's bolster has usual light wear otherwise very good
